what advantage running 23" front tyres ??
Old Feb 9, 2003 | 08:12 PM
1prokiwi's Avatar
Default what advantage running 23" front tyres ??
Are 23" better than stock sizing ...im just about to order some new maxxis fronts and wondered if i should get 22 or 23 " ??
cheers
Prokiwi
Old Feb 9, 2003 | 09:07 PM
JMAC650's Avatar
The 23" tires give you more ground clearance.
Old Feb 9, 2003 | 09:57 PM
Eaglecollector's Avatar
Some people also believed that it helped their twitcy steering problem. However I think that issue was handled in the 03 models. I corrected mine with a-arms (I needed any way, bent my stock ones) and proper toe out. Since my a-arms are chrome i like the 23" tires for clearence[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 10, 2003 | 08:12 AM
Ward660R's Avatar
I also think it has something to do with the "contact patch" of the tire. A larger diameter should give you more tire on the ground than a tire with a smaller diamter.
Old Feb 10, 2003 | 08:17 AM
Hightower's Avatar
they roll over obstacles better too.
As far as looks go, I like the proportions of 20"rear/22"front or 22"rear/23"front.
if you go to 22" rears, it will decrease caster angle in the front, but 23" fronts will help counteract it and leave caster fairly uneffected.
Old Feb 10, 2003 | 09:57 AM
BadBoyDS's Avatar
Puttin 23's on my machine greatly helped with the steering problem. I wish I bought them before a got the stabilizer.
They work great and roll real easy. The downside is that my turning radius has nearly doubled.
I'll trade that any day for good steering[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 10, 2010 | 06:49 AM
chrisboy27's Avatar
Does changing to 23" tyres on the front still allow the use of front mud guards
Old Nov 10, 2010 | 07:41 PM
DuneRider650's Avatar
I ride a little here and there......
Depends what brand of tire....i never had a problem although it was VERY close...as most of us have removed the front fenders cant say for sure.
Old Nov 10, 2010 | 11:49 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Not a problem at all. I've never seen the lugs on Razrs, Holeshots, or any other 23"tire rub on the fenders. Even the AMS Whiptails that are a true 23 inches don't rub.
Old Nov 11, 2010 | 03:37 PM
chrisboy27's Avatar
Thanks both.
I am running lug tyres like razr so this is greet. As it will give me better ground clearance.
Would you change the sprocket. Or should I give it a go on the 23" first
