Rancher Tire Question?
Old Jan 5, 2000 | 10:15 PM
TerryM's Avatar
I was just wondering since the Front tires on the Rancher are a different size than the back, can I run different size tires, or do the front ones still have to be bigger? Thanks in advance.
Old Jan 5, 2000 | 11:22 PM
BigRed450's Avatar
I just read the specs on the Rancher and guess what, the front and rear tires are the same height, the back are 1" wider but the rear rims are 1" smaller then the front (11" Rear and 12" Front)
Tire height is your only concern here, so you can put on any size you wish as long as all four are the same height. 12" ForemanES rims would probably fit on your rear.
Ride the "WILD COUNTRY" , South Gillies, Ontario, Canada. Y2K Honda 450ES <a><marquee>The "BIGGER BIG RED"</marquee></a> <a>JJTH</a>
Old Jan 8, 2000 | 05:09 PM
phalynx's Avatar
Has anyone tried any larger tires on the Rancher 4x4? I want to add a "Bigfoot" type kit to mine. I want to know what will fit and how they perform with the engine?
Thanks,
Scott
Old Jan 8, 2000 | 05:33 PM
TxDoc2's Avatar
You should not have any trouble with a bigger tire. I have 300, which cannot compare to your 350, and I am running 25" Vampires all the way around on ITP steel wheels that are 12 x 7.
toonces
Oct 16, 2019 12:11 PM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
rcappie4
Jul 18, 2015 07:51 AM
Scottma518
Jul 16, 2015 09:19 PM
