Predator Weight Savings
Old Feb 11, 2003 | 06:42 PM
pleasure4qt's Avatar
Default Predator Weight Savings
Been looking at the quad and there is alot of weight to be saved on this quad if you had the time to do the trimming and grinding of extra metal and modify some of the brackets etc...
Replace the rear hubs and the use of more aluminum where some steel is now and I'm pretty confident that you wouldn't loose any strength in the frame or quad itself and you could get the weight down to Raptor numbers. I'll wait till the 6 months warranty runs out first and have it powdercoated Raptored Blue. Just like my beer "Out of the Blue"
Old Feb 11, 2003 | 07:03 PM
GE4x4's Avatar
Yeh!, but if you put the tires that are on the Predator on the Raptor, the Raptor would weigh 412lbs. My tires weigh 13lbs more then the Raptors.
Old Feb 11, 2003 | 07:13 PM
Yeah, I realize that also but I like the heavier tires cause I hate flat's.
If the raptor was the same width up front and had the same rear axle and all 4 tires and same wheel base it would be heavier.
badgerboy1
Sep 26, 2017 06:11 PM
shimanok2
Jan 29, 2016 07:37 PM
Robinhood
Dec 26, 2015 10:28 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Elkaholic
Sep 6, 2015 02:44 PM
