Mojave Shake
Old Feb 13, 2003 | 01:12 AM
mojave300ex's Avatar
Default Mojave Shake
I just got my mojave back together from a re-ring and it shakes terrible I mean BAD what could be the problem, I knwo their is a wudruff key in the left balancer but I hope it's not a bent crank. This thing won't rev and it very sluggish due to the shake
Old Feb 13, 2003 | 08:42 PM
Sprout's Avatar
You might want to double check the cam timing.
Old Feb 13, 2003 | 09:22 PM
if my timing was off could it make everything not work proper like the balancer and cause the shake?? Thanks It sounds a little less severe now
Old Feb 14, 2003 | 12:35 PM
Sprout's Avatar
Not to concern you, but if the timing on the cam was off the valves could of been hitting the top of the piston. When you take it apart double check the valves and lifters, along with clearance.
Old Feb 14, 2003 | 11:24 PM
Chris142's Avatar
If all it got was rings then the woodruff key and other things in the bottom end shouldn't have been touched.
There should be 43 links between the 2 "dots on the cam gears with the crank "t" lined up with the groove (you will find this after you remove the upper plastic plug on the left side of the case).
The exhaust "dot" should be just above the top of the valve cover gasket area. The intake is 6 deg above the same place on the opposite side, or 43 links.
Sorry I'm terrible with explaining things, HTH
Old Feb 15, 2003 | 01:58 AM
I'm tearin it down this weekend I think the timing is off, but could this cause the shake?
toonces
Sep 5, 2015 01:14 PM
Ferhat Durakovic
Aug 26, 2015 07:04 AM
austinwhitton
Aug 11, 2015 06:21 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
