400EX what first MOD i should have done
Old Apr 15, 2000 | 03:51 PM
Lucis's Avatar
i have only rode it 3 hour so far just got it today hehe...............but im looking ahead and would like to know what mod i should start first.........
Old Apr 15, 2000 | 05:42 PM
Johnnnn__H's Avatar
Improveing the intake flow with a filter, airbox lid, holes in the lid or whatever, is cheap and help anny other mod that you do along the way.
A pipe will help also but costs quite a bit more.
435cc warrior
Old Apr 15, 2000 | 05:51 PM
Lucis's Avatar
is there a after market flowbox or just makingm y own hole just as good........................as for the pipe i want one for sure . i like the sound a aftermarket pipe soundsbut for a pipe dont i have to have the jets done any info would be great
Old Apr 15, 2000 | 09:44 PM
GB400's Avatar
First mod to do, should be to check and see if you are getting full throttle. Some of the 2000 models are adjusted where they don't get full throttle.
GB
Old Apr 15, 2000 | 10:21 PM
Rotorhead51's Avatar
Don't drill the airbox. You may need it. Leave it on with a stock machine, take it off if you install a pipe. You can increase the main jet as well.
Old Apr 16, 2000 | 03:12 AM
Lucis's Avatar
If you could please post in order what mods i should have done i have about 2k to waste on MOD when it broking in and i have had some time to get use to going from 2 wheels to 4
and what brands i should look at thanks for the help
Old Apr 16, 2000 | 06:19 PM
fasttrax's Avatar
Get a k&n airfilter w/ outerwear. I got one for mine and was pleased when I inspected it after riding that the sand wasn't all over it with the airbox lid off. I switched from a wb foam to this and rejetted. Its alot more responsive throttle-wise.
Old Apr 17, 2000 | 09:12 AM
sAyIt_fmf's Avatar
With out trying to sound rude....There is really no way anyone can tell you what the best first mod is for you.... You need to ride the machine and figure out what you can do to make it better for you.... If you follow the pack (so to say) you might end up with a machine like everyone elses that will not work for you.....
I am used to riding a banshee,,,,so when I hopped on the 400ex (girlfreinds)....I wished for more snap in the throttle.(airbox/sprockets/cam? maybe/pipe).... then I wanted to get rid of the tendency to roll around corners(tires).....some higher rpm's would be nice..( cdi box).....The stock shocks are pretty good for now....eventually (for me).....a wider front end would be nice.
When building a bike....It's always better to think into the future rather than with the pocket book (spur of the moment).....Some mods just don't work well together....and it's nice to kinda think about where you want to go with the machine in the end...and buy accordingly.
good luck
Old Apr 17, 2000 | 01:18 PM
rhino99's Avatar
If you've got 2k to spend on mods you can do just about anythng and everything to it. Start with a filter and a pipe. Then I would get some suspension, works shocks work well and dont cost an arm and a leg. Then a cam, and whatever else suits your fancy. I would love to have 2grand to spend!
Old Apr 17, 2000 | 07:02 PM
400exalltheway's Avatar
white brother e-series pipe, k&n filter w/outer wear, cam , new card, tcs shocks( a must if you're gonna be jumpin), lonestar 2+in a-arms, lone star axcaliber axle(2plus in. on both sides, stering stabilizer, new tire I got shedder( go with beadlock if you planning on racing), kil switch, lonestar swing arm up to 14in longer than stock, race front, ceet graphics kit, unlimitd rev box, renthal handel bars, and the list goes on and on, e-mail for sites to spefic things you're intrested
Y2K 400ex lots of mods www.400ex.homstead.com
