Chain Lubrication?
Old Apr 15, 2000 | 06:17 PM
Motorhead's Avatar
I was wondering how often you guys lube up the chains on your quads and dirt bikes? I just got a 400EX, and the last thing I want to do is wear it out prematurely. Are there any other things I need to know about, like grease points, something else? Thanks.
Old Apr 15, 2000 | 07:09 PM
JRM's Avatar
JRM
I hit my O ring chains with chain lube every other ride, or whenever it is dry.. I lube non o ring chains every ride....iF in sand dont lube them at all becasue oil attracts sand it will act like sand paper
Old Apr 15, 2000 | 11:56 PM
Mike300EX-99's Avatar
I clean and lube after every ride. It takes the most abuse out of anything on your bike.
Old Apr 16, 2000 | 12:31 AM
Stroke9's Avatar
Turn the wheels so you can apply chain lube to the entire chain, check chain slack and adjust if necessary.
Occasionally remove the master link and take the chain completely off and wash it in parts washing fluid, re-lube in a pan immerse in chain lube if possible, re-install then adjust chain slack.
Old Apr 16, 2000 | 02:31 AM
azrob's Avatar
I use Maxum chain wax after every 3 hours of riding or so. When crap builds up on my chain, I use a pressure washer to remove it, let it dry then use the chain wax again.
Old Apr 16, 2000 | 11:42 AM
Y2K300EX's Avatar
My brand new 300ex doesn't have a master link. My dealer says that it is an endless chain. That isn't to great when I try to take it off and clean it.
Old Apr 16, 2000 | 12:09 PM
ATV_MAN's Avatar
Hi i know this isn't about chains but has anyone ever heard of a "Honda 200 trx sx" (atv)?? that's what i have and i have never heard of or seen one like mine.
Old Apr 16, 2000 | 12:33 PM
4ooex's Avatar
yea i used to have a 87 200 sx but i sold it
Old Apr 16, 2000 | 12:41 PM
ATV_MAN's Avatar
400ex what colour was it and did you have a problem with the chain?, because mine always comes loose.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
