boost
Old Feb 17, 2003 | 11:01 AM
2002bansheeman350's Avatar
Default boost
wat is the piont of the boost bottle?
it is soposed to even out the air suply to both cylenders right?
y cant you run a line to your air box and just filter the thing?
will a bigger bottle help out with the power or will it wreck my motor?
thank s
kevin
Old Feb 17, 2003 | 11:29 AM
Batoutahell's Avatar
Default boost
I have read a fair amount on this subject lately. It seems if you have a bottle, or tube that is matched to the engine it will indeed help out. I dont think it is a huge amount, but it does help.
There was an article I read, I will try and find it for you. It explained why it is there and also that it needs to be sized to your engines needs. That is probably why most that get them dont feel a difference, because they are just buying a one size fits all bottle and not one that is fitted to the needs of the engine.
I will try and find the article. Also toomey has some good info on their site regarding the bottle.
I am not sure what you are talking about filtering, so I wont comment on that.
Bat
Old Feb 17, 2003 | 11:51 AM
AlkyBurninX's Avatar
Default boost
The way I see it, a boost bottle, crossover tube, etc just keeps the air flowing. Instead of air flowing when the reeds are open then stopping abruptly when they close, it gives the air a little more room to take up so it doesn't have to stop.
Yamaha has been using boost bottles since the early 80's (maybe even late 70's) starting on the YZ dirtbikes. The TRI-Z also had a boost bottle. My YZ490 has an aftermarket reed spacer/boost bottle. But as far as I know, yamaha is the only company to use them.
According to all the info I have read, the size doesn't matter. BY the way, I have a boost bottle on my banshee and didn't notice any difference. I keep it on there for the looks.
I would also be interested in the article Bat. My thinking may be way off base.
Old Feb 17, 2003 | 12:11 PM
Default boost
wat i meant by filtering it is if you take out the bottle completelly there r open holes and u dont want stuff in there so u would filter it. but do u think that if you take it it off it will help that was part of my question. but yea i would be interested in that article too
Old Feb 17, 2003 | 12:19 PM
DuneDevil's Avatar
Default boost
You do not want to take the tube off and put a filter there. You will lean out the motor. You are just letting in fresh air with out going through the carbs.
DuneDevil
Old Feb 17, 2003 | 01:24 PM
Default boost
Here is one article here
There is some info on toomeys site also. I will look for the other article later.
Also, what dune devil said is right on. Dont remove the tube and put filters there. Major meltdown would occur if it would even run.
Later
bat
Mikegriff92
Technical and How-To Articles
Oct 26, 2015 02:40 PM
Aug 18, 2015 01:00 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jun 8, 2015 11:05 PM
ShortyRock
Mar 22, 2001 11:29 PM
