Motor oil question
Old Apr 16, 2000 | 01:32 PM
Hondapride's Avatar
I just bought a 1998 Honda TRX250 Recon and I want
to change the oil. but I dont know what kind of oil I should go with. Could you please tell me what kind I should use for my bike.
Old Apr 16, 2000 | 02:18 PM
JRM's Avatar
JRM
The honda GN4 will do great, or any motercycle oil I would use 20W50 in warm weather and 10W40 in cold
Old Apr 17, 2000 | 06:49 PM
Slug's Avatar
I just had my recon in for servicing, and the mechanic told me to use castrol 20w-50w in the summer and 10w-40w in the cold months. He said he puts Castrol in all the machines he works on, and he does'nt see any more wear than with the high price specialty oils. I think the main thing is to keep your air filters clean and change the oil religiously!
Old Apr 17, 2000 | 06:53 PM
Hondapride's Avatar
ok Thanks
but how do you clean the air filter yourself
Old Apr 18, 2000 | 12:12 AM
JRM's Avatar
JRM
1. remove it and soak in solvent
2. get most of the oil and dirt out by soaking in solvent, then squeeze as much solvent off as you can
3. now use dish soap and water to remove the fine dirt, when all clean rinse with water and let dry
4. soak filter in heavy gear oil or filter oil, squeeze excess out and re instal the filter useing greese on the sealing side to keep dust out
Old Apr 18, 2000 | 05:10 PM
Hondapride's Avatar
does this really work?
And what kind of solvent?
Old Apr 18, 2000 | 10:36 PM
Motorhead's Avatar
Just generic, normal solvent. I think gasoline will work too.
Old Apr 20, 2000 | 11:21 PM
wcy2k400ex's Avatar
I would suggest Honda GN4 motor oil. It's designed for all Honda ATV's. The oil not only supplies the engine, but the transmission as well. The GN4 is less foaming than automobile motor oils. You can get the stuff at your local Honda dealership.
Old Apr 21, 2000 | 01:50 AM
boomer's Avatar
I run Mobil 1 10w-40 synthetic motorcycle oil in my bike. It is good for cold starts, and keeps the motor cooler also. It DOES NOT harm wet clutches, or make them slip.
Old Apr 21, 2000 | 03:37 AM
JRM's Avatar
JRM
Dont use gas to clean the airfilter, it will slowly eat away the glue holding it together, I use paint thinner as solvent
