Hub oil
Old Feb 18, 2003 | 09:44 PM
highwayman's Avatar
Default Hub oil
I was looking at another post (actually a scan of the service manual) and it showed putting hub oil in at 4 o'clock. I was thinking I could put it in at 2 o'clock and let it drain at 4 o'clock will this work or should it be squirted in at 4 o'clock?
Old Feb 18, 2003 | 10:28 PM
tmbwn's Avatar
Default Hub oil
what you want to do if fill the hub enough so when you turn the fill hole to 4 o'clock the fluid starts to dribble out. the hubs do not take a lot of fluid.
Old Feb 19, 2003 | 09:11 AM
walexa's Avatar
Default Hub oil
Makes no difference at what position you put fluid into the hubs. If you put too much in, just let it drain down to the proper level @ 4 o'clock.
Waylan
