425 Transfer Case
Old Feb 19, 2003 | 01:04 PM
Cleaner's Avatar
Default 425 Transfer Case
I have a 1996 425 Magnum. This past summer the bearings in my front Transfer Case went bad. I think they were bad for awhile. Has anyone else had the same problem because they just went bad again after less than 20 hours of service?
Old Feb 19, 2003 | 06:28 PM
ftwflh's Avatar
What are you calling the front transfer case?
Old Feb 20, 2003 | 09:06 AM
Cleaner's Avatar
The housing unit between the drive chain and the front drive chain. The bearings went bad last summer, so I replaced them. Plowing snow this weekend the 4wd quit working so I tore it apart and the bearings were shot again and the housing cracked this time. Just wwanted to know if it was a common problem or not.
Old Feb 20, 2003 | 09:44 AM
walexa's Avatar
I would say it is a fairly uncommon problem........but I haven't owned one. Are you keeping it greased? Anyway, I may have one of those housings I could sell cheap if you're interested. Go to partsland.com and look up your bike. Give me the part# and I will tell you if I have a used one or not.
Waylan
Old Feb 20, 2003 | 10:37 AM
Cleaner's Avatar
It is actually called the Center Tightner Assembly. The part number is 1380130. Thanks
Old Feb 20, 2003 | 10:48 AM
walexa's Avatar
I don't have one.........I have some parts from a older 350, but the part numbers are not the same. It was worth a try though. You should check your local dealer to see if he has a junk magnum laying around........just an idea.
Waylan
flyin-lowe
Dec 1, 2017 03:18 AM
EIF
Apr 20, 2017 07:15 PM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
WilliamBos
Sep 22, 2015 04:07 PM
