Grizzly 660 clutch slipping, what's the cure
Old Feb 19, 2003 | 04:09 PM
Skiddy660's Avatar
Default Grizzly 660 clutch slipping, what's the cure
THis started after plowing in the big storm we had this week.
Symptoms
When I take off slow it slips, but when I jump right into it it will spin the wheels and go.
I apprisiate any help you all can give me. [img]i/expressions/face-icon-small-sad.gif[/img] [img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Feb 19, 2003 | 09:12 PM
Skiddy660's Avatar
just checking
Old Feb 19, 2003 | 10:02 PM
carver's Avatar
ARE YOU SURE ITS A CLUTCH PROB. A WORN BELT WILL USUALLY CAUSE THESE PROBLEMS, BUT IN REVERSE ORDER. I DON'T OWN A GRIZZ, THERE MAY BE ADJUSTMENTS THAT I AM NOT AWARE OF.
Old Feb 20, 2003 | 07:20 PM
Skiddy660's Avatar
Thanks, but I don't know of any adjustments. With the way the Grizzly's system works, it all leads to the Belt.
Old Feb 20, 2003 | 08:21 PM
mich660griz's Avatar
skiddy
there is no adjustment on the clutch of the grizzly. i have never heard of one slipping, unless it was wayyyy durty. or wet.
i dont see it being a worn out belt at all, but probibally water in the clutch housing, or worse yet, mud or sand. probibally water though. check to see if one of your snorkle boots came off, or loose. if not, then think about if the snow got into one of the snorkles. take it apart and give her a real good cleaning, followed by more grizzly grease, and i am sure it will be fine.
good luck
WilliamBos
Sep 6, 2015 10:53 AM
Brandon400
Sep 5, 2015 08:44 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
cdstang
Aug 31, 2015 07:52 AM
