Raptor Pro flow foam question?????
Old Feb 19, 2003 | 08:45 PM
Raptor010101's Avatar
Default Raptor Pro flow foam question?????
I am putting a pro flow foam on my raptor, with a Yoshi slip on, no lid with an outerwear cover over the airbox and DynoJet kit 148/150, my question is about the red outer foam filter that comes with the proflow filter system, I ride in the winter and summer in average dirt conditions and rarely in sand, should this be used or is it for extreme conditions????? does it effect jetting??
Old Feb 19, 2003 | 08:50 PM
rudyraptor's Avatar
I have the foam but i never used the orange outer one. Might not be good, hopefully someone will say. I have had no trouble yet except for my 2001 tranny just failed.
Rudy
Old Feb 20, 2003 | 12:25 AM
RaptorRacer1's Avatar
I have the foam proflow system also, no lid, Outerwears airbox cover. I rarely use the red prefilter. I only use it when I am riding in sand. I have never had a problem. It does affect jetting a little bit. It will richen things up a little bit.
RR1
Old Feb 20, 2003 | 03:10 AM
raptor23's Avatar
I also have the Pro flow kit and been running the pre filter with airbox cover on.But i ride mostly in real dusty areas or sand.I just put the exhaust on,so will find out how it does this weekend with cover off with outter filter on.Have had to problems so far.
Old Feb 20, 2003 | 03:42 AM
ew660r's Avatar
I run the exact same setup as you but with a WB-e series. I don't think you need it unless it's real dusty conditions.
Old Feb 20, 2003 | 09:53 AM
FISHER1648's Avatar
I ride in dust and sand (Dust is much finer than sand) and use the red pre-filter. I like it because it's much easier to clean and it appears to traps 95% of the crud so I dont need to clean the inner part as often.
Old Feb 20, 2003 | 10:26 AM
garyc660R's Avatar
I have never used the outer filter...I don't ride in sand though. Jetting sounds good....I recommend lowering the needles 1 notch too clear up mid range (no lid introduces turbulence in the intake tract).
Old Feb 20, 2003 | 10:57 AM
Also my photos in the directions for the Proflow are fuzzy, So in the actual air box do I just cut out the front peices of plastic under the Billet , or is there some cutting somewhere in the rear of the box like the two pieces in the middle sticking upward???
Old Feb 20, 2003 | 01:53 PM
XxDumontRaptorxX's Avatar
You leave the big pieces that are located near the back of the airbox, what you cut is the front little plastic things that go lengthwise in the front of the airbox, there about an inch long. If you go no lid i think thats all you have to cut, drill away!
Old Feb 20, 2003 | 08:49 PM
I ended up going with the lid on snorkle cut out and had more power than with the lid off, I ended up with 148/150 DJ, 4th clip and 3 turns out. It snaps very nice wheelies. Thanks to all who helped out I appreciate the knowledge you shared !!!!!!!!!!
Firefighter400
Oct 8, 2022 06:38 PM
GNorm
Aug 1, 2015 11:06 AM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
yambam13
Jul 4, 2015 01:49 PM
