Mikuni Carb?????
Old Feb 20, 2003 | 05:54 PM
jericho's Avatar
Default Mikuni Carb?????
I purchased a Dynojet kit for my Predator and before I attempt to install the jets and all I would like a breakdown of the carb. The only thing I have is the service manuel that I made a copy of from off of the Polaris site. I went to the mikuni site and they do not have anything on the 42MM BSR carb. Does anyone know where I can find any info????
Old Feb 20, 2003 | 06:10 PM
SP700RACER's Avatar
The service manual is the only one i know of, but the needle clip diagram is incorrect in the pic. only the thin washer and nylon spacer go under the c-clip, thick washer goes above
the c-clip and under spring.
Old Feb 20, 2003 | 06:11 PM
sfehr's Avatar
My advice is carbs aren't very diffucult just take it apart slowly and take mental pictures and remeber where stuff goes. I don't know how mechanically inclined you are but most of the hoses are self explanatory and over all it is pretty simpe to figure out. I wouldn't worry about getting all the diagrams because the one you have in your service manual is probally the best one you are going to get because a mikunin diagram wouldn't show you where all the hoses hook up and get routed because it varies slightly by application. Well good luck I hope this gives you some self confidence with it. Later, Seth
Old Feb 20, 2003 | 07:58 PM
jericho's Avatar
Thank You both for your help. I have done work to carbs in the past but I am not to sure about this one. When it comes to drilling(air mixture plug) and stuff I get a little nervous.
Old Feb 20, 2003 | 09:24 PM
modquad's Avatar
You might also be able to get a little info from your local tech. Don't expect them to tell you everything (their paycheck relys on your service patronige), but a question here and there can't hurt.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
