wheres the transmission drain plug on 2000 trailblazer???
Old Feb 24, 2003 | 09:15 PM
polsrisracer2003's Avatar
Default wheres the transmission drain plug on 2000 trailblazer???
i have a 2000 polaris trailblazer and could not find the drain plug for the transmission , i went to the dealer & the mechanic already went home, and the salesman didnt know. also it seems to not have much power at all starting on a steep hill it just boggs down, it has a fresh engine and new tires . could this be the belt? i can hear it hit the cover every once in a while. how hard is it to change the belt? thanks for any info..[img]i/expressions/face-icon-small-confused.gif[/img]
Old Feb 24, 2003 | 10:17 PM
modquad's Avatar
The trans drain-plug is integrated in with the rear trans torque stop. On the left rear of the trans, you'll see a threaded bolt sticking out and contacting the frame. You loosen the locking nut, and back out the bolt. To re-install, back bolt out til it contacts the frame, then go 1/2 turn further. Lock down the locking nut, and refill trans. As I recall, it only holds about 11 oz. when filling from empty. Use the Polaris synthetic lube.
Old Feb 25, 2003 | 12:02 AM
talonhawk's Avatar
The bogging could be bad fuel, fuel vent line plugged, carb or a clogged dirty
air filter.
Old Feb 25, 2003 | 12:42 AM
im pretty sure its not gas because it gets ridden frequently and gets fresh 91 octane fuel. it only bogs down bad at the bottom of steep hills, everywhere esle its flawless. thanks for info.
SDR-II
Sep 29, 2015 01:06 AM
Captjay
Jul 23, 2015 12:33 PM
shewshew989
Jul 14, 2015 03:09 AM
shewshew989
Jul 14, 2015 02:54 AM
