94 400 explorer transmission noise
Old Feb 27, 2003 | 12:21 AM
planemechanic's Avatar
Default 94 400 explorer transmission noise
My 94 explorer transmission make a popping sound when the shifting lever is put into high or reverse. Can the shifting rods be adjusted longer to force the slide gears closer togather. A dealer told me the transmission had to come apart and the slide gears needed replaceing. Need help?[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Feb 27, 2003 | 09:43 AM
Farmr123's Avatar
One end of the shifting rod is right hand threaded, the other end is left hand threaded. After loosening the jam nuts, turning the rod one way or the other has the effect of lengthening or shortening the linkage. You will have to just experiment with how much to move which rod which way.
For what it is worth, I had to re-adjust the linkage on my Xplorer at about 5500 miles or so, and it is still doing fine at 7250 miles now.
Farmr
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
