gaps and temp
Old Feb 28, 2003 | 05:43 PM
FastYellow650's Avatar
Default gaps and temp
ok this is weird to me, i have a tapping noise in my motor after changing cams and springs, ive done this about 3 months ago, when i first fired her up she had one hella noise, i checked the gaps between the cams and tappets and two were way off then, i but the new shims in and rechecked them again that was about 3 weeks ago it was about 50 degrees, there was one that had no gap at all, today 30 degrees, i check them again to make sure what shims i needed to order, well today the one that had no gap now has .004" could the weather being 20 degrees cooler make that big of a difference, what is going on here, im lost and not really knowing what to do
thanks
Old Feb 28, 2003 | 09:22 PM
JSsDS's Avatar
The engine has to be dead cold, that means it has to sit for aprox 8 hours before checking the valves. Let it sit over night and check again.
Also ensure that its on top dead center, cam marks alligned.
Old Feb 28, 2003 | 11:03 PM
its been setting for 3 weeks, its been setting in the back of my truck for a week and i pushed to the back, it was dead cold the last time i check it 3 weeks ago,
Old Feb 28, 2003 | 11:56 PM
DSDuneCrazy's Avatar
dead cold meaning room temperature..... around 72 degrees F
Old Mar 1, 2003 | 12:02 AM
how in the world am i going to get the bike to 72 degrees, sence i dont have a garage, i guess ill need to find a friend with a warm space to work on it, thanks, im sure i can find somewhere to do it
Old Mar 1, 2003 | 01:15 PM
JSsDS's Avatar
I didn't think of it the first time but many have had problems with their cam chain tensioner after reassembly, maybe what the noise is? check out markys site, he has manual chain tensioners available to fix the "auto tensioner blues".
Old Mar 1, 2003 | 04:48 PM
Hightower's Avatar
Whenever I check clearance, I always turn the crank at least two full revolutions before stopping at tdc and locking it. This insures that all buckets at tightly against the shims and stems before I start, whether its shim over or shim-under bucket.
Ron Wood reccomends .007-.009 clearance, apposed to the shop manual. I shoot for the high side, rather have a couple extra than not enough.
shimanok2
Jan 29, 2016 07:37 PM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Halffast17
Sep 11, 2015 02:30 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
