400ex mods
Old Apr 18, 2000 | 03:21 PM
quadman440's Avatar
How much of a power increase will i get fron a big gun exhuast or a dmc and a cam that drops in with the stock valve springs. Plus a dyno jet kit.
Please answer
Thanks Matt
Old Apr 18, 2000 | 11:29 PM
Air's Avatar
Air
I switched from a Big Gun to a DMC It is a bit better at top end. Get a web cam 450-451 grind directly from web cam. It is the largest cam you can get without changing springs and guides.
You wont believe the change. A larger carb would also help after.
99 426ex , Web Cam, FCR carb, CT revlimiter, DMC exhaust, XCT's ,K&N, One kit, Renthal 400EX bend bars
http://www.trxoutlawz.com/
Old Apr 19, 2000 | 12:27 AM
Mike Frey's Avatar
Air, when are you going to post pics of you newly-modded machine?
Old Apr 19, 2000 | 08:42 AM
JAKOOL's Avatar
When using the Web Cam 450/451 grind cam do not forget to also change your rocker arms. There are hardwelded rockers also available at Web Cam. The hardened camshaft will wear the stock rockers faster.
Old Apr 19, 2000 | 04:23 PM
quadman440's Avatar
Where can i order directly
Online site?
phone number?
Thanks matt
Old Apr 20, 2000 | 09:34 AM
JAKOOL's Avatar
www.webcaminc.com
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Sep 23, 2015 06:23 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
