440EX QUESTIONS
Old Mar 5, 2003 | 11:16 PM
Optic400's Avatar
Default 440EX QUESTIONS
Im thinking of goin to a 440, will i need a bigger carb? how reliable is it? is it a big horsepower increase?
Old Mar 13, 2003 | 03:28 AM
ORANGE400exRACER's Avatar
MY 440 CAN EASILY BEAT A RAPTOR WITH A BIG GUNS PIPE AND JETTING TIME AND TIME AGAIN. I RUN A STOCK CARB BUT A FCR CARB IS THE WAY TO GO. ONLY ADVICE IS TO TRY TO SAY UNDER 11:1 RATIO BECAUSE HEAD GASKETS TEND TO BLOW. A LARGER OIL TANK IS A MUST BECAUSE 440EX'S RUN VERY HOT. LUCAS OIL STABLIZER HELPS BY REDUCING OIL TEMPATURE BY 6 DEGREES.
Old Mar 13, 2003 | 11:30 AM
speeddemon1988's Avatar
i was just wondering how many horepower do you gain by adding a 440 kit with pipe filter and carb.
Old Mar 13, 2003 | 01:52 PM
Horse Power on a 440ex depends on the builder and how much you do to your motor. For example my Trinity 440ex has a 12:1 J.E piston, pro-flow head work (porting), valve work, a all-around WEBCAM with DMC exhaust and a stock carb. It's put's out 40-41H.P.
Curtis Sparks 416 kits are awesome and CT racing has a very good 440 kit ($1200.00 without a pipe).
Old Mar 18, 2003 | 02:35 AM
RURacing's Avatar
With the known 400ex rod problems I would go with a 440 bore and stroke and replace the weak rod! Powroll has a stroker crank and rod that is made 2mm shorter and uses a Std. 416 piston this is the best and longest lasting way to go. You also do not run in to the head gasket problems the the 440 all bore.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
