head gasket
Old Mar 6, 2003 | 04:31 PM
fastone21's Avatar
Default head gasket
Can I run a stock head gaske with 11.5 compression or do I need to change to an aftermarket on or cooper.
Old Mar 6, 2003 | 04:55 PM
ThePunisher's Avatar
Default head gasket
Yes you can use the stock head gasket, just make sure it is a new one.
Old Mar 6, 2003 | 05:16 PM
DuneMe's Avatar
Default head gasket
You may want to upgrade your head bolts to the Pami ones. TVI can get them for you too. They are a harder metal so not as prone to stretching.
Stock head gasket works fine. Get a new base gasket too.
Also, you will probably need heavy duty clutch springs with this mod (TVI, Pami, Ron Wood) and gasket for the clutch cover just in case.
Old Mar 6, 2003 | 05:20 PM
JEFFROE's Avatar
Default head gasket
rwr springs are the weakest of the bunch.
Old Mar 6, 2003 | 10:18 PM
FastYellow650's Avatar
Default head gasket
who are some aftermarket head gasket makers, does pami, tvi, rwr make them or do they use someone else and just sell them
Old Mar 6, 2003 | 10:53 PM
SANDMAN430's Avatar
Default head gasket
the copper one i got from tvi was made by cometic
Old Mar 7, 2003 | 02:36 AM
DuneMe's Avatar
Default head gasket
Pami (TVI) use an all metal gasket with an automotive caulking / sealant coating on both sides (re-usable). Pami sells them but, I am not sure if they manufacture them or not (not much to it really since it is just metal.)
RWR uses stock gaskets (I think) since they don't offer a bigger bore.
Not sure what Sam Coe does for their 730.
Old Mar 7, 2003 | 10:29 AM
SANDMAN430's Avatar
Default head gasket
like dune me said the metal one is reuseable and it is cheaper i think it was $44 with shipping the stock one i got was $50, the sealer they recommend is gasgacinch
Old Mar 7, 2003 | 11:07 AM
fastone21's Avatar
Default head gasket
which one is better and what is the thickness of both gaskets. will the metal gasket give you more compression. Do I have to worry about blowing head gaskets with 11.5 or 12.1 comp.
Old Mar 7, 2003 | 11:14 AM
Hightower's Avatar
Default head gasket
the stock gasket is metal with a black coating on each side. What makes the Pami better? How is it reusable - its the coating that comes off from sticking to the head and base that usually warrants replacement on most motors - does this Pami coating not stick?
Has anybody really ever seen stretched head bots? that's a new one on me. You'd think the aluminum crankcase would tear before the steel would stretch.
