MBRP Works Great
Old Mar 10, 2003 | 07:41 PM
pads's Avatar
Default MBRP Works Great
I just put a MBRP slip-on and a Dyno Jet Kit and everything seems to work great. I put in a DJ180 main, clip 2 down, air screw 2 turns out. It seems to run great-no back-fire no hesitation. I have to run it a little longer and check the plug. Do these settings sound right? I'm running a UNI filter in the stock air box. Also, how much is a Graydon CDI. I was reading on another thread that mentioned a Graydon. I thought Ron Woods was the only other box until the programmables come out.
Old Mar 10, 2003 | 09:13 PM
JSsDS's Avatar
If it runs good then its dialed, only you will know so ride it long and hard (insert pun here) and check the plugs.
There are a few guys on here that run the Graydon and I havn't heard anything negative accept the cost. Woods give you the best bang for the buck though.
Mkp
Mar 28, 2020 03:50 AM
WilliamBos
Jun 11, 2015 05:57 PM
hoopduerr
Jun 10, 2015 03:00 PM
vipers
1) Engine problems..
May 31, 2015 09:12 AM
Steven Bandemer
May 27, 2015 07:39 PM
