does the baja need an aftermarket cdi?
Old Mar 11, 2003 | 12:29 AM
blastnbaja's Avatar
Default does the baja need an aftermarket cdi?
I'm alittle confused. I've read hear that the baja doesn't require a cdi because they upped the rev limit. is this true? what did they up it to? And if it is higher than would an aftermarket cdi be much of a help? Also i've read about cdi's that have no rev limit and cdi's that just increase your limit. which is better and how high can you rev the motor w/o causing damage? Thanks
Old Mar 11, 2003 | 12:42 AM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Frist it is almost impossible to over rev a rotax and second i belive they only gave about 350 rpm with the baja and last it makes a amazing amount of top end your missing out on !!
Old Mar 11, 2003 | 12:44 AM
XxDumontRaptorxX's Avatar
You need a new cdi box, only way to go.
Old Mar 11, 2003 | 01:01 AM
SANDMAN430's Avatar
get the cdi you will see the light and know what we are all so happy about
akguy31
Aug 31, 2019 04:34 AM
EIF
Apr 20, 2017 07:15 PM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
cboler9
Sep 24, 2015 08:35 PM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
