2000 Honda Rancher 350 es
Old Mar 12, 2003 | 09:59 PM
turkeyfan's Avatar
Default 2000 Honda Rancher 350 es
My Honda Rancher is stuck in Reverse. I was advised that these machines had a re-call on a electric shift component. I never received a re-call and now the thing won't work. It is stuck and the selector switch clicks only on forward. I was able to free it up once. Please advise.
Old Mar 13, 2003 | 01:44 AM
toytech's Avatar
try looking underneath and find the reverse cable and make sure it is releasing all the way, and make sure the cable is in the holder properly. good luck. also check your clutch adjustment.
Old Mar 14, 2003 | 09:04 PM
dzzy's Avatar
You didn't say if you could shift out of reverse manually with the lever included as part of your toolkit. Assuming you can't, the best possibility is the tran linkeage. That's the topic of the shift bulletin you refer to. The part of the linkeage that turns the shift drum cracks. The typical symptom is stuck in rev or 5th, depending on which side of the shift arm cracks. You can access it by removing the front engine cover, or just bring it to a Honda dealer as I believe that is a current bulletin and they would have no problem warrantying it as long as that's what the problem is (vast odds are it is).
Old Mar 14, 2003 | 10:48 PM
turkeyfan's Avatar
[img]i/expressions/face-icon-small-smile.gif[/img]Thanks for the info. Your are correct as I finally did take it to a Honda dealer. Although Honda would rather refer to the fix as a shift update rather than recall, The machine will be repaired under the bulletin you were speaking of. Thanks for your input.
Turkey Fan
aka Gary
Old Mar 16, 2003 | 11:06 AM
dzzy's Avatar
There was also a frame reinforcement bulletin on the (I think) 2000's. Have them update that as well if it hasn't been done already.
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
Scottma518
Jul 16, 2015 09:19 PM
Scottma518
Jul 10, 2015 12:42 AM
