Raptor Steering Stem
Old Mar 13, 2003 | 07:33 PM
Bass's Avatar
Default Raptor Steering Stem
Is there away to lube? Mine seems to be a little hard to trun. I couldn't see anything that looked like I could lube.
Thanks for your help.
Old Mar 14, 2003 | 01:33 AM
RaptorRacer1's Avatar
Take off the front plastic, then the gas tank. There are two bolts that hold the top of the stem mount to the frame. Remove these (you will have to bend the locking tabs back), then you can remove two plastic bushings with a couple rubber oil seals. I would replace all the plastic and rubber parts with new ones for best performance. Pack some grease inside this space where the stem would rub, then reassemble. Remember to bend the locking tabs back in place. You can also lube the bottom of the stem mount, but I have never had this apart, so I don't have any info on that process. Good Luck!
RR1
bmxatv10
Oct 14, 2022 06:23 PM
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
black_thunder
Sep 22, 2015 07:59 PM
