Leaky Base Gasket on Raptor
Old Mar 17, 2003 | 12:38 PM
garyc660R's Avatar
Default Leaky Base Gasket on Raptor
No contamination in oil, but I have visible fluid gathering at the base of the bead. Anyone had this problem?
Old Mar 17, 2003 | 01:27 PM
Ward660R's Avatar
Yep, but mine was more than just gathering fluid, it made a BIG mess. The entire clutch side of mine blew. I had just fixed it Thursday, then Sat the tranny and one way went.
Are you sure its the gasket and not the llittle oil line in the case? They would be easily confused.
Old Mar 17, 2003 | 01:40 PM
warrior007's Avatar
My raptor is the same, not a whole lot but you can tell cause its a little damp and dust collects there. My warrior was the same
Old Mar 17, 2003 | 02:00 PM
garyc660R's Avatar
Thanks for the replies guys. My leak is coming from around the rear of the head, and partially on the clutch pack side as well. You guys have no oil contamination at this point? Oil will get milky quick if coolant is introduced. THats my main concern. I can't believe it's leaking....I may just wait until the rod blows before digging back in....LOL.
Old Mar 17, 2003 | 02:22 PM
warrior007's Avatar
I thought you were talking about the base gasket, if its the head gasket it will contaminate the oil pretty quick, antifreeze is really bad for cranks.
if it really is the base gasket there isnt really much to worry about, theres no water jackets or anything, just so long as your oil isnt pouring out.
Old Mar 17, 2003 | 03:05 PM
garyc660R's Avatar
Yep, it's the base gasket....I should have indicated that on my 2nd message.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
