need help with my 45mm carb
Old Mar 17, 2003 | 04:40 PM
jetsnow600's Avatar
Default need help with my 45mm carb
Well this last weekend i hooked up my 45mm carb. Then i turned on the fuel and thats when the **** hit the fan. Fuel poured out the drain on the bottom of the carb and out the vent line on the side of the carb. Before i hooked up the carb i check the float bowl and it seemed to not be sticking so i dont think that is the problem??? Sean
Old Mar 17, 2003 | 05:50 PM
Jetjock16atWork's Avatar
try tappin on the float bowl with a wrench gently do try to get the floats to move, it really sounds like the floats are stuck.
Jetjock16
Old Mar 17, 2003 | 06:50 PM
SANDMAN430's Avatar
if the bowl has been off there is the valve that the floats actuall control, i have had them come and cause the vent to over flow.
Old Mar 22, 2003 | 02:52 AM
jetsnow600's Avatar
i think it was just a stuck float bowl because i took the carb back off, took off the bowl, messed with the float a little bit, hooked it back up and there was no leaking. So i pressed the start button and it started up right away. Man, i am stoked. Too bad it has the razors and sand paddles on it, guess i will have to change them out on sunday and try it out(Goin snowmobiling tomorrow) Thanks for the info. Sean
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
