Scrambler 500 chain broke
Old Mar 18, 2003 | 02:03 AM
waloud's Avatar
Default Scrambler 500 chain broke
Can I just buy a masterlink and use the old chain? Or should I just go ahead and buy a new chain and sprokerts. Any suggestions on companies would also be good.
Old Mar 18, 2003 | 08:43 AM
hannahj's Avatar
so your master link snaped into mine did that to when i ramped it. I boughta new chain and sprocket but i learned the hard way it was dark and i didnt no my sproclet was broke so my chain was way to short so i cut 3more links out of it nd thn i found out my sprocket was broke so ibought a new one and then my new chian was to short so there was $50 wasted. I bought another one and i once i put it on i had it really loose so itwouldnt break again but guess you dont have to have them loose and i broke the sprocket because of that $30 wasted. I bought a emgo 12t sprocket then and i havent had a problem yet. I think it helped my lowend alittle because stoc it 13t. I tried using my old chian but the master links were to small that i bought the stock chain is pretty thick i couldnt find one that would fit it so i could put the saftey thing through it the groves wouldnt show. see ya
Old Mar 18, 2003 | 09:54 AM
Farmr123's Avatar
Wrap the chain around your rear sprocket, holding it tight where it meets. If you can lift the chain off the sprocket opposite where the chain meets more than 1 or 2 mm, it is worn enough, you should get a new one. Get new sprockets when you get a new chain, it will help chain life greatly.
Get the top of the line chain from a brand-name maker. I like DID X-ring chain myself, but there are plenty of others probably just as good. Just go with the highest-strength o-ring style chain you can find. A cheap chain is like a cheap tire. Saves you a few bucks up front, but not worth it in the long run.
Farmr
Old Mar 18, 2003 | 05:32 PM
waloud's Avatar
How hard is to replace the front sproket? What size do I need for more on the bottom end? Do I get the same size on the rear as factory? Thanks guys.
Old Mar 18, 2003 | 06:11 PM
401's Avatar
401
front sprocket is easy to change.A snapring is all that holds it .As for the rear,go up in the #of teeth for more bottom end,lower #for mor top end (just takes a little longer to get there).Should have a #36 for the rear(stock)
Old Mar 18, 2003 | 06:13 PM
401's Avatar
401
Oh yeah,you will have to adjust your chain length if you go really big or really small.Don't think you will have enough adjustment.
Old Mar 18, 2003 | 06:16 PM
MNScrambler's Avatar
Do you check the tension with someone sitting on the machine or not? And how much slack should there be?
Old Mar 18, 2003 | 06:31 PM
401's Avatar
401
not neccesary to have someone sit on bike.Freeplay should be about3/8 of an inch.Should have small tag on swingarm with measurements.Sticker or tag is located by the chain gaurd,right side.
Old Mar 19, 2003 | 12:46 AM
Thanks 401
Old Mar 19, 2003 | 10:09 AM
Farmr123's Avatar
Just remember, if you have a 4x4, that when you change the gear rario to the rear wheels (changing sprocket size) you can and will affect the way the 4wd engages. Gear it up too much, and you will have to really spin before the front engages: gear it too low, and the front might not dis-engage properly.
