Scrambler 500 chain broke
Old Mar 20, 2003 | 01:56 PM
hannahj's Avatar
Default Scrambler 500 chain broke
what if you only went down 1tooth in the front i have a 12t and stock was 13t i havent saw a difference yet will there be
Old Mar 20, 2003 | 03:44 PM
401's Avatar
401
If you drop your countershaft (front) sprocket # you will gain more low end acceleration.If my old memory[img]i/expressions/face-icon-small-smile.gif[/img](27 years) is correct ,1 tooth diffrence in the front is like 2-3 in the rear.The diffrence you should see would be in acceleration,but a loss of top end speed 1-2 MPH maybe more could be felt.
Old Mar 20, 2003 | 07:35 PM
hannahj's Avatar
i mean i differnce in my 4wheele drive i no it was supposed to give more alitte more low end
Old Mar 20, 2003 | 08:05 PM
NCScrambler's Avatar
401 you are right about the 1 down in front is the same as 2-3 up in back. I went two up in the back with my Scrambler recently. I noticed a huge difference in bottom end, but with all of my mods It was not what I wanted because I had way too much wheel spin on take-off. I changed back to the factory size and I can go about 25 foot now without the major wheel spin I experienced with the bigger sprocket. I think It is something you just have to try If you are willing to spend the money for the bigger sprocket in back. If you aren't satisfied with the results, you can change it. I got a chain a few links too long, long enough for the larger sprocket in the rear, and tried it. Didn't like the results so I went back to factory, cut off a few links and had the same as factory. If you don't get enough results with two in the back, cut the chain down to factory and put 1 tooth smaller in the front. I wouldn't recommend going more than i down in front or you will lose alot of top speed. Just my experience and .02!
fordfaithful21
Dec 7, 2015 05:52 PM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
1000gade
Sep 9, 2015 03:35 PM
bmark0610
Sep 7, 2015 09:42 PM
