What Dynojets Are You Running And For What Setup ?
Old Mar 19, 2003 | 01:02 AM
RepTaR660r's Avatar
Default What Dynojets Are You Running And For What Setup ?
I'm running the stage 2 needles with the clip on the 4th. 180/185 mains. I'm at sea level.
Craycraft 686
Old Mar 19, 2003 | 01:30 AM
kyraptor23's Avatar
was running 148/150 with needles on the third position but couldnt dial it in right as it warmed up so switched to 155/160 mikunis, much better.
Old Mar 19, 2003 | 04:24 AM
XxDumontRaptorxX's Avatar
im running stage 2 needles on the 3rd clip down with 190:185 at 600 ft above sea lvl
Pro flow foam filter - outer wear
stage 2 web cam
doubled valve springs
bored .5 over - wiesco 11:1 piston
big gun exhaust - header - muffler
Old Mar 19, 2003 | 07:25 AM
Ward660R's Avatar
Xx is that dyno jets????
Who has the chart that compares dyno jet sizes to the regular mikuni sizes?
Old Mar 19, 2003 | 08:00 AM
garyc660R's Avatar
I am running 175-177.5 mikuni mains along with DJ needles at a custom location around sea level. Mikuni mains are roughly 10 sizes larger than DJ mains. My setup is 10.75/1 JE, Stage 1 HC, P-bomb header and an e-series /w 12 dics and no endcap....this puppy is loud.
Old Mar 19, 2003 | 08:18 AM
Ward660R's Avatar
Thanks Gary, for some reson I was thinking it was a progressive gain.
example: 148DJ=150mik, 150DJ=155mik
Old Mar 19, 2003 | 10:58 AM
Rob4092's Avatar
I noticed the stock Raptor comes with a 140 / 145 jet combo (5 numbers in between).
I installed a White Brothers R4 Silencer (only) and increased my jets to 145 / 150.
I see a lot of folks only have 2 or 2.5 between their main jets. As an example, I noticed kyraptor23 has a combo of 148 / 150.
Why do some folks have 5 numbers between and others have 2 or 3 numbers in between?
Does my 140 / 145 combo sound right for a new Raptor with a WB Silencer, stock airbox and no other mods? I ride at sea level.
Thanks!
Old Mar 19, 2003 | 03:54 PM
yamaha4life's Avatar
how can you use dyno needles and mikuni mains wouldnt that equal out to like
200 dj???
Old Mar 19, 2003 | 05:48 PM
Ward660R's Avatar
You can't, TRUST ME!!! If you are you will NEVER get it tuned in right. I struggled with that for a long time and didn't realise thats what my problem was. Swapped needles and had WAY better luck then.
Old Mar 19, 2003 | 06:27 PM
RepTaR660r's Avatar
does anyone run 180/185 dyno mains ?
