Which is really the best cam??
Old Mar 21, 2003 | 02:19 AM
lilMike's Avatar
Default Which is really the best cam??
I was looking at these numbers; how can the Hot Cams stage 2 cam be so much better than the Web Cam? The cam is going into a 686 with 11.1 piston ratio, HMF Exhaust, K&N clamp on filters to the back of the carb., Plasma Ignition Booster and +6 homemade swingarm ext.. This bike is used mainly for racing the 300ft. dirt drag and sum riding at LA Dunes. Future mods are over sized valves with a major porting job, carb. bore, and flyheel cut.
Web Cam = (valve lift) .365 ; (Duration @ .50 degrees)( Intake, Exhaust) 248 & 245
Hot Cam Stage 2 = 9.8mm & 10.3mm ; 246 & 259
Stock = .320 & .345 ; 224 & 227
Old Mar 21, 2003 | 02:20 AM
14mins's Avatar
It is. All those that pulled there 636/637 out have liked the big improvement.
Old Mar 21, 2003 | 11:40 AM
lilMike's Avatar
Is this cam the top choice of 727 machines also? Does anyone know if 1mm or 2mm oversized valves are the way to go?
