power reed
Old Mar 23, 2003 | 04:17 AM
cOoLdevil's Avatar
Default power reed
hi all what do you think of the boyesen power reed's for banshee . i know that the best reed's is v-force but i want to know is the boyesen power reed's worth the bucks or not and do they make any difrance in the power in low end and the mid range and top end ?
Old Mar 23, 2003 | 08:51 AM
OutOfControl's Avatar
Default power reed
I am currently running the power reeds. I didnt notice a HP gain but I did notice better throttle response.
Old Mar 23, 2003 | 08:16 PM
WyoDuner's Avatar
Default power reed
I have a set of Boyeseen dual stage reeds - couldn't tell a difference between them and stock and I even switched back and forth a few times.
Old Mar 24, 2003 | 01:13 PM
cOoLdevil's Avatar
Default power reed
what do you think of the boyesen Pro Series Reeds is it bester than the power reed's and do i feel any hp gane with the Pro Series Reeds or same as the power reed's
Old Mar 24, 2003 | 01:49 PM
WyoDuner's Avatar
Default power reed
I never tried the pro reeds - I believe they are carbon fiber which tends to chip and/or crack easier than fiberglass. I used to think the reeds helped with throttle response when I first got my Banshee but I later figured out that it was all in my jetting. Now that it is jetted right it is very snappy off the bottom. The high compression domes helped the most and the +4 timing helped too.
I guess if I HAD to change the reeds I would go with the V-force but for $200 I don't think they are worth it either.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
bvolks
Sep 13, 2015 12:57 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
Jason Richards
Sep 4, 2015 06:17 PM
