How much hp with a Pro-x 310 kit?
Old Mar 26, 2003 | 02:10 AM
Bartman's Avatar
Default How much hp with a Pro-x 310 kit?
I am going to be installing a Pro-x 310 kit on my R and was wondering what kind of HP to expect. I have a FMF Fatty pipe and FMF silencer. The carb is stock and am running a K&N. Also, I'm at about 500 feet above sea level. What size main jet should I be running? Thanks for the help
Old Mar 26, 2003 | 03:17 AM
elsancho's Avatar
the horsepower varies on teh porting. as well as teh jet size.. you could probably expect to run a ..180 or .182 main jet
Old Mar 26, 2003 | 03:32 AM
DaBeechMan's Avatar
who is going to do your cylinder work, what carb are you going to run, what type of porting. Give a few more specifics please
Old Mar 26, 2003 | 02:26 PM
briansgi's Avatar
You might want to invest in a new larger carb with the 310 kit. I have ESR's 310 with the 9 porting along with their pipe/silencer and an Airstryker 38mm carb. Check out servicehonda.com on the carb, they have very good prices. With the above setup that I've mentioned, I'd start out with around a 200 main and change the pilot jet to a 52 to 55. With the race dome installed, the HP should be around 50 if I was to guess.
Semms40oz
Mar 8, 2005 11:58 AM
hondaguy13
Jul 22, 2004 02:14 AM
LT80
Jul 15, 2002 06:00 PM
Keenan
Dec 4, 2001 09:44 AM
