Help with the Raptor, bumfuzzled!
Old Mar 26, 2003 | 10:11 AM
Blue660R01's Avatar
Default Help with the Raptor, bumfuzzled!
About 3 months ago I installed a hotcams stage 1 cam. Once installed I hit the start button and the battery was dead. Used the jumper cables and she started up. Ever since then I have been having to jump it quite a bit. I thought "bad battery" cause I hardly ever ride it and it has been an especially cold winter. Well on a recent ride it started up fine all day without a jump. Till we stopped about 3 miles from home for a short break and it wouldn't start back. I had to bump start it cause it wouldn't jump. The starter acts like it has trouble turning the motor over. And first and foremost it is not the one way gear. I'm quite familiar with that situation. I took the side cover off the starter and took out the starter gear that turns the flywheel. The starter turned much slower than it was supposed to. Took the starter apart and cleaned it out and WALA, starter seemed to work fine then, turned much faster. Put everything back together and hit the start button, still acts like it has trouble turning the motor over. It's not the battery, I bought a new battery and even hooked it to a car battery to make sure it was getting enough cranking power. But, here's the kicker...I can take the plug out and it cranks just as it is supposed to. Put the plug back in and it struggles to crank over. I'm thinking at this point something with the decompression mechanism. That thing was a pain in the butt when putting the cam in. What do you guys think. If I can't get it fixed I'm going to get rid of the POS, it always breaks down for some reason or another.
Later,
Jason
Old Mar 26, 2003 | 10:22 AM
NotuRaptor2's Avatar
Sounds like you are on the right track with the decompression setup. By the way, welcome to the "OneRide" 660r club. /NotuRaptor
Old Mar 26, 2003 | 10:30 AM
sixsixT's Avatar
Come on now. I have never had a problem other than a battery cable come loose.
It sounds like the decompression mechanism to me also.
Old Mar 26, 2003 | 10:46 AM
garyc660R's Avatar
Sounds like the decompression mechanism is'nt even working. Member of the "1-ride" club here..[img]i/expressions/face-icon-small-smile.gif[/img].
Old Mar 26, 2003 | 11:49 AM
Blue660R01's Avatar
Bartlett, your comment is interesting. I just put a new cam chain in when I done the cam install. It broke before because the screws backed out of the one way bearing and broke the chain. Lucky for me that was all the damage it done. But shouldn't the tensioner take up the slack if there is any? A new chain shouldn't stretch this soon should it? My dad seems to think my problem still lies in my starter, but keep in mind the starter seems to turn fine.
Old Mar 26, 2003 | 11:53 AM
LtRaptor's Avatar
Do a compression test before you take it apart. The decompressor working properly will give you somewhere @ 40% of max. might be out of time by a tooth
Old Mar 26, 2003 | 01:55 PM
Ward660R's Avatar
Yes I think it has something to do with the pin not hitting at the right time. Mine does the same thing and it is from the cam chain being stretched. Do you use a degree key?
Old Mar 26, 2003 | 05:24 PM
RacinJason's Avatar
I got it
YTX-20LBS battery and goodbye to your starting problems
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
