scrambler pipe hot on right leg
Old Mar 27, 2003 | 01:23 PM
ajo771's Avatar
Default scrambler pipe hot on right leg
I just got an HPD trailpipe from RCR. I was getting ready to install it and had the plastic guard off of the stock pipe. So I took it for a ride (stock pipe no heat shield) and it got hot on my leg - quickly- without the shield.
Will I have this problem with the HPD pipe (heat on his right leg without the heat sheild in place)?
I was going to have the pipe ceramic coated, but not if I'm going to wind up keeping the heat shield in place.
Rick was thinking a custom heat shield. Any thoughts?
Old Mar 27, 2003 | 01:31 PM
POLARISFREAK's Avatar
I had to leave the heat shield on my wife's quad and put a thermal barrior on the pipe in order to keep the heat down. You might be able to put a thermal barrior coating on it and go without the heat shield. The thermal barrier coating made a huge difference.
Old Mar 27, 2003 | 01:32 PM
FTZLT250r's Avatar
With the trail pipe, you pretty much have to run some type of guard. I assume you re-jetted for the pipe.
Old Mar 27, 2003 | 02:09 PM
MegaCrash's Avatar
I used aluminum tape to make a thick heat shield where the pipe touched the plastic and that worked pretty well. You can buy it at WallMart in the Auto department.
exmotocrosser
Sep 13, 2019 06:12 AM
mrtidy
Feb 3, 2016 05:00 PM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
greg86hd
Sep 16, 2015 12:32 AM
