Chain adjustment on 300EX "HELP"
Old Mar 29, 2003 | 05:40 PM
Warrior8me's Avatar
Default Chain adjustment on 300EX "HELP"
Need some help here.
I have a 300EX that the chain keeps coming lose. The more I ride, the loser it gets. Adjust it back and it gets lose again. The quad was purchased used. (Just to let you know.)
Looking in my service manual, it says that the axle bearing holder should be turned clockwise to increase slack and counter clockwise to decrease slack. My quad is the opposite. Clockwise decreases slack and counter clockwise increases slack. I am thinking that something was put together wrong when someone put new bearings in.
Any thoughts?
I forgot this. The service manual says nothing about having to losen the axle bearing holder stop bolt. I have to losen it to adjust my chain.
Old Mar 29, 2003 | 06:40 PM
Nordy's Avatar
My sister in law has a 300ex and on hers you adjust the chain by turning the bearing holder towards the dirt to get the chain tighter and the opposite to get it loose. The only thing I can think of is that your set screws are striped ( the 2 allen screws ) which means they are not pinching like they should. Maybe start your looking in this direction. I hope you find your problem.
Old Mar 29, 2003 | 06:47 PM
Warrior8me's Avatar
Thanks for the reply.
The screws are fine though. They tighten up great. I'll take them out to check them just to make sure.
Old Mar 29, 2003 | 09:07 PM
dzzy's Avatar
In all the eccentric type adjusters that Honda uses that I have ever adjusted personally, clockwise IS tighten and counter clockwise is loosen. So your manual must be wrong about that. If your hub is actually moving back (mark it and make sure this is the case), it bears removal and inspection. Having to loosen the stopper bolt to turn the eccentric could indicate binding, improper fit or breakage. If not, make sure the swing arm pivots aren't shot, making it impossible to adjust the chain properly. Also, some cheap, non o-ring type chains can stretch REALLY fast.
Old Mar 29, 2003 | 09:10 PM
dzzy's Avatar
Just to clarify the previous post, clockwise as you are facing the left rear wheel from the outside.
Old Mar 29, 2003 | 09:23 PM
Warrior8me's Avatar
Dzzy,
Yes to your ? about facing the tire. How long is the factory axle holder bolt? I think this one was replaced with one that is way to long.
I took the rear end apart tonight. What a mess. Some people are to stupid to have ATVs. I have to ge a new Axle bearing holder assembly. It is TRASHED!!!!
Old Mar 29, 2003 | 10:43 PM
Warrior8me's Avatar
Update.
Thanks to the dumb *** that worked on this bike last I have to order $239.12 in parts. That price is from the Service Honda web page. Anybody know a better place to order from?
The Axle bearing holder assembly was in wrong and badly wore out.
Old Mar 30, 2003 | 04:18 PM
kooshdaddy's Avatar
you can get a new aftermarket bearing carrier that is better than stock for 150 or less. Ebay is a good source for that type of thing. i got one for my 250x for $100 and it is a double row bearing carrier. That is where i would check. Honda parts are always more expensive than the aftermarket.
Old Mar 30, 2003 | 04:59 PM
Warrior8me's Avatar
Koosh,
I looked on Ebay and found the ones you are talking about. Did you bet yours from nbs distributing?
It seems to be in a kit form.
Here is the link Carrier
Old Mar 30, 2003 | 08:41 PM
Warrior8me's Avatar
I purchased the carrier. Now I have to order the o-rings that I need.
