Got a new 45 and need help
Old Mar 30, 2003 | 11:29 AM
dsking's Avatar
Default Got a new 45 and need help
ok what would you all recomend with this setup at sealevel, fmf slip-on, 45mm w/ direct mnt k&n, rwr cdi.
I also bought the carb as a custom/harly carb off ebay so its not a rwr carb cause his is like 400$ what will i need to change it over and where and what do i ask for when i go get jets?where can i get the softer return spring local shop or only rwr? my local shop told me the tm45 is crap cause he cant tune the bottom end in is it hard to get it tuned correctly and will it help if i get the accelerator pump activated?
geeze thats allot of q's but i hope you guys can help thanks, vic
Old Mar 31, 2003 | 11:14 AM
SANDMAN430's Avatar
the tm45 is fine if you ride the coast put in a 160 main jet and a 45 or 47.5 pilot not sure about the needle but seems it was on the third and like a 1 1/4 turns out on the air screw, i don't think you will notice any bottom end problems mine works fine and like you all i heard was the bottom end is crap well there isn't enough of a problem to bother me and i like to whellie a lot and most of mine are on the low end and it works fine. that jetting worked fine at the coast and it works here in bend also so that is about 4000ft.
Old Mar 31, 2003 | 01:20 PM
jetsnow600's Avatar
sandman430, are you running a 160 with a direct mount filter or the airbox?
Old Mar 31, 2003 | 01:48 PM
dsking's Avatar
thanks for the reply where can i pick up the jets? what do i ask for? cause i herd there are a few different ones hex and round? appreciate the jetting specs im going today to go get those jets too.
Old Mar 31, 2003 | 02:01 PM
SANDMAN430's Avatar
jetsnow yes it is a k&n on the carb, and i i think it works good i thought i would see more of a bang from the 45mm than i did but i also think i was being easy on it at first, as our sand started to dry my quad was getting faster and faster. i have my wifes to compare to and hers is why faster than other ds's that we have come across. not to mention banshee she loves racing those[img]i/expressions/face-icon-small-smile.gif[/img] the jets are large rounds. seems most bike shops have them there like $3.25 here in bend. if you you need more help call the guys at cascade yamaha/ skidoo they helped set-up my 45mm, had them look at the 42 on mine and said it was fine, so they seem to do really well but they do a lot of jetting with the snowmoblies. ask for mark 541388-8727
Old Mar 31, 2003 | 02:17 PM
dsking's Avatar
thanks sandman ill call some shops in roseburg to see if the got any if not ill go to eugene.
