Airbox=cooler
Old Mar 31, 2003 | 03:39 AM
mystereid's Avatar
It's official, I've been duning for over 30 years.
Default Airbox=cooler
For us carb mount filter guys, I haven't tried this yet but what if you take your unused airbox and slip in a metal or plastic liner, then use sprayfoam to fill the gap around the liner for insulation. Some foam glued to the lid and you have a little cooler. If you drilled it you could even use the drain.
Old Mar 31, 2003 | 11:44 AM
Batoutahell's Avatar
I put some duck tape on mine, and I could fit 5 bottles of water and a few chunks of ice. It works pretty good. Only problem is the pipe is close to the box and melts the ice. But your idea might work better.
Bat
Old Mar 31, 2003 | 04:12 PM
mystereid's Avatar
I tried sticking water botttles in mine but the box picks up alot of heat from the pipe and engine. That's where the insulation comes in.
mywifesquad
8
Sep 21, 2015 08:20 AM
Canamaniac!
Sep 15, 2015 06:19 PM
mbriggs
Sep 13, 2015 10:47 AM
metal249
Jul 24, 2015 01:00 PM
ghost civic
Jul 20, 2015 12:36 PM
