How to adjust the chain???
Old Mar 31, 2003 | 09:46 AM
Birdoprey's Avatar
Default How to adjust the chain???
I must be an idiot, because i can't seem to figure out how to adjust the chain on my DS! I see the pinch bolts in the carrier, and i know the brg. housing has to rotate to adjust the chain(the axle is offset in the housing), but HOW do ya get to it to rotate it???
Old Mar 31, 2003 | 11:02 AM
SANDMAN430's Avatar
put a floor jack under the carrier and then look at the sprocket, you will see the arms it mounts on on some of them you will see a hole look thru there and spin the tire until you see another hole then put in a allen wrench or some sort of rod i think there is something in the tool kit. then you spin the tire front or back until you get the proper, tension. it is 7/8 slack with you on the quad, not without rider.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
craacker
Sep 9, 2015 04:32 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
goosemasterkl
Aug 23, 2015 11:36 AM
