Banshee Filter Setup/Dunes
Old Apr 25, 2000 | 11:43 AM
artoux's Avatar
Which is the best Banshee filter setup for the dunes to not let sand in? I am mostly a woods rider but a few times a year i go to the dunes.
I am thinking about Toomey T-5's with the pro-design filter 2-1. Or the FMF Fatty's with the K&N with the Power Core two silencers. I want to keep sand out first and get the pipes and jetting later.
2000 Banshee
1998 300ex
1995 Blaster
Old Apr 25, 2000 | 12:01 PM
SteveNB1's Avatar
Do not do anything but the K&N. I have the foam pro design and I am now rebuilding my biike. I have pictures to show the damage.
Old Apr 26, 2000 | 09:55 AM
rweissen's Avatar
Where are the pictures? Do you have the pro-flow air box mod with the foam filter or just the pro-design foam filter on the stock setup?
I understand that the riding conditions determine the type of air filter you should use. If you ride in real dusty conditions the foam filter is the way to go. If you ride in sandy conditions the k&n is the way to go. Either way most everybody recommends the pro-design pro-flow airbox mod. This will seal up the opening from the airbox to the intake boot, preventing any sand or dirt falling down into the carbs.
Old Apr 26, 2000 | 11:36 AM
notfastenough's Avatar
I run two K&N's in the sand dunes 1 per carb with outerwears that is the most popular set up I have seen plus if you need to rejet it is super easy just pull one carb clamp off at the reed side slide the carb out tip it over and change the jet try doing with an airbox in there
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
