Sportman 90 Sprockets
Old Apr 8, 2003 | 06:50 PM
Sportmanrider90's Avatar
Default Sportman 90 Sprockets
Does anyone know where i can get 19 front sprockets and 25 rear?? Also a cdi no rev limiter and a pipe and clutch springs ... what website and fro how much???
Old Apr 8, 2003 | 07:31 PM
BLASTERDEVIL2's Avatar
have you tried rockymountainatv? otherwise i don't know. good luck.
Old May 11, 2003 | 04:44 PM
With the CDI and the sporkets will i be going 50 also how fast will i go if i just got the CDI?
Old May 15, 2003 | 02:59 AM
predator530's Avatar
you may want to look into an exhaust system also they make one for the predator 90
Old May 15, 2003 | 03:01 AM
oh the exhaust might fit your scrambler they are the same machine but different plastic
Old May 15, 2003 | 06:48 AM
TRexTommy51's Avatar
You can get these machines to run in the low to mid 40's with different sprockets and a cdi change. I'm not sure what the speed change will be with just a cdi change. A pipe is the big "Wake Up" for these machines as is the case with most others. To get the power to run up over 50, You will need pipe, clutch mods, cdi, sprockets, and maybe a bigger carb. Just remember that if you try to get more top end without increasing power, you are going to give up some bottom end power.
Old May 24, 2003 | 11:38 AM
If i get the pipe what else would i need? And what size jets?
Old Jun 12, 2003 | 10:40 AM
RENARACER's Avatar
MY SON STARTED RACING A POLARIS SCRAMBLER LAST YEAR.SO I KNOW THE HASSLE OF BUILDING A HOT LITTLE BIKE.THERE'S NOT MANY PLACES TO BUY GOOD PARTS.I HAVE FOUND THAT WRH RACING IS ABOUT THE BEST FOR SCRAMBLER PARTS.
Old Jun 12, 2003 | 08:48 PM
YFZRacer's Avatar
it is a lot easier to find stuff for a lt 80 or honda 90 then the polarises
buddieboy
Dec 9, 2016 05:50 PM
Jazperman
Aug 7, 2016 08:12 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Dammar
Aug 26, 2015 07:12 PM
