AAEN pipe
Old Apr 8, 2003 | 09:12 PM
SuzukiQuadrunner160F's Avatar
Default AAEN pipe
I found a cheep AAEN pipe i was just wondering if it would add any top end. It is a AAEN Megaphone Muffler for a 425 magnum with a UNI filter and a Polaris White Primary clutch spring.
Old Apr 8, 2003 | 09:13 PM
Default AAEN pipe
If i raised the frount sprocket 1 tooth how much more top end would that give me?
Old Apr 8, 2003 | 11:08 PM
Default AAEN pipe
anyone
Old Apr 8, 2003 | 11:16 PM
modquad's Avatar
Default AAEN pipe
Be a little patient. I'm not personally familiar with the tweeking the 425, but anything to help the air get in, and get out is gonna give you HP.
NCScrambler's Avatar
Default AAEN pipe
I looked at this pipe on their site but I can't really say because I haven't run one. The best thing to do would be to call them at (262)522-8981 and ask a tech about what you are asking. Just tell them you are thinking of buying one and what will it do for your ride. They are very friendly and helpful so I wouldn't hesitate to ask them.
Old Apr 8, 2003 | 11:24 PM
Default AAEN pipe
alrite ill call them thanks
Old Apr 9, 2003 | 12:06 AM
ftwflh's Avatar
Default AAEN pipe
Hey if you are patcient and keep an eye on Ebay you will find a Supertrapp on there every now and then.I got mine for $100 total.It made a huge improvment and is tune able.As for the topend it didnt make that much dif but it gets there faster.Your is a 2x4 right?If you go up one on the front and you loose too much on take off you can off set it by dropping a tooth on the rear.I think 1 tooth up on the front = 2 down tooth on the rear or real close to that.
Old Apr 9, 2003 | 05:12 PM
Default AAEN pipe
yea thanks i was trying to get teh frount up a tooth instead of the rear down cause i don't really want to cut links outa my chain its pretty new.
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
bvolks
Sep 13, 2015 12:57 PM
