removal of airbox
Old Apr 25, 2000 | 09:11 PM
suzukimd's Avatar
What happens when you remove the airbox on the scrambler 500. I am installing a k&n airfilter and need to know if I remove the airbox if there are any mods I need to make.
thanks,
Doc
Old Apr 25, 2000 | 10:46 PM
Hermz's Avatar
First off, i don't see why you have to remove the air box, the ait filter goes inside of it, if i remember right, so there hsould be no reason to take it off. Anyway, it should be removable and be able to be put back into place without any mods
---85 Trail Boss, still going strong---
Old Apr 26, 2000 | 12:06 PM
CaptNemo's Avatar
The element should be a replacement type of element that drops into the place of the stock filter element.
Hope that helps
Old Apr 26, 2000 | 05:45 PM
THEXOTIC1's Avatar
I would not remove the air box because when all your friends are riding in the rain or wet ara you will be sitting on the trailer whishing u had an air box. When the filter gets wet the motor will start to miss so just shut it down and wait another dry day
Old Apr 26, 2000 | 09:31 PM
Hermz's Avatar
Why shut down if you got some water in the airbox? Just pull the drain plug, wait a few secs, and the filter will dry itself off after a little bit of riding
Old Apr 26, 2000 | 10:53 PM
A400L's Avatar
If your stil running the stock carb there should'nt be any reason for you to remove the airbox.
If you go up to a 42mm you can, then run a K&N RU1770 (6" angled filtercharger, w/a prefilter), but as stated above stay awat from water. I run a 39PWK on my 400 and use a K&N w/o the airbox. But, you limit yourself on the types of terrain/conditions you can ride in.
Old Apr 27, 2000 | 02:13 PM
suzukimd's Avatar
thanks for the info. I left the airbox alone.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Canamaniac!
Sep 15, 2015 06:19 PM
mbriggs
Sep 13, 2015 10:47 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
