sportsman steering
Old Apr 10, 2003 | 03:40 PM
MuDmAnIa's Avatar
Default sportsman steering
does anyone with a sportsman have the problem of the steering pulling hard to one side at times
Old Apr 10, 2003 | 04:54 PM
NCScrambler's Avatar
Sounds like your 4wd may be locking in on one side intermittingly. Try raising the Sportsman off the ground, all 4 wheels off, and see if one front tire is locking in once in a while. If it is check for oil in the hub and change it if it hasn't been changed in a while. Inspect everything inside well while you have it apart. That should fix it unless it is a mechanical problem inside the hub, If it is, come back for more info.
Old Apr 10, 2003 | 07:03 PM
carver's Avatar
this happened to mine, you can normaly goose it in reverse to disengage the hub. (hold the reverse override button down) and yes, change your hub fluid. if you ride in lots of mud & water i would suggest removing the entire hub & cleaning it well in addition to changing the fluid regularly.
Old Apr 10, 2003 | 09:52 PM
tjschmi1's Avatar
Hello, may also be an alignment issue. While your atv is raised on jack stands, center the handlebars. Both fron tires should be slightly toed in. Check your service manual for details.
Tim[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 10, 2003 | 09:57 PM
MuDmAnIa's Avatar
i think it may be the hub fluid i do lots of mud and water riding and i have not added oil to the hub or changed it thaks for the help
Old Apr 10, 2003 | 10:09 PM
scrambled6910's Avatar
It might be the driver who seems to not be able to steer. Ive never had trouble with either of you machines and ive done some pretty nasty stuff on them too.
Old Apr 10, 2003 | 10:35 PM
MuDmAnIa's Avatar
ask shawn even he complained about it pulling to one side and he rode it for only 10 min
MuDmAnIa's Avatar
and what u do on it isnt what causes it to lock up it normally does it when i'm goin slow or in reverse
Old Apr 10, 2003 | 10:42 PM
i just think the steering is finally unbalanced it could be from u hitting foot tall stumps. It is prolly a tie rod.
Old Apr 10, 2003 | 10:54 PM
ScRaMbLeRiZeD's Avatar
it just needs so good old fashion maintenance
