Performance Module P650 HELP!
Old Apr 11, 2003 | 07:05 PM
CAM650's Avatar
Default Performance Module P650 HELP!
I just put in a performance module for my P650 and now it won't switch into 4wd! WHat has happened?
Old Apr 11, 2003 | 07:23 PM
CAM650's Avatar
Have I blown a fuse? Is there a fuse for that?
Old Apr 11, 2003 | 08:26 PM
nyroc's Avatar
You might have blown a fuse.
If you got a crappy module (a cheaper model), you would need to make sure that the KEBC and speedometer are both still plugged into the stock speed sensor, and that the CDI is plugged into the modulator.
You might have to do some wire tracing to figure out which goes where.
Old Apr 12, 2003 | 12:03 AM
CAM650's Avatar
Thank you for your responses. I hooked it up when i got it and it worked fine. I unhooked it and rewired and it wouldn't shift into 4wd. Fuse?
Old Apr 12, 2003 | 12:43 AM
CAM650's Avatar
Well, it's not a fuse, I checked them. Any other suggestions?
Old Apr 12, 2003 | 08:42 AM
NovaKaw650's Avatar
Recheck your wiring; something's not right. Is the speedo still working? You've cut the pink wire to the CDI, not Te'ed into it, correct? The box output has to be spliced to the pink wire going to the CDI, and not to the end of the pink wire going back to the speed sensor. If you've spliced to the pink wire w/o actually cutting it off, you may experience the problem you describe. If the box is hooked up correctly, the 4x4 problem is being caused by something else.
Old Apr 12, 2003 | 09:04 AM
NovaKaw650's Avatar
And, as red650 said, your hooked up to the right box?
Old Apr 12, 2003 | 12:44 PM
CAM650's Avatar
It's hooked up correctly, it wheelies and acts much differently now. I didn't tie into the pink wire, I spliced it. It's not a fuse. I have no idea what it could be. When I swith into 4wd, it makes the little noice it's supposed to make but it doesn't shift. I put it up in the air to make sure it wasn't saying it was in 2wd and actually it was in 4wd. It won't switch.
Old Apr 12, 2003 | 06:26 PM
NovaKaw650's Avatar
It must be something unrelated to the module.
Old Apr 12, 2003 | 06:38 PM
Scotia650's Avatar
Hey Scott,
I talked to a guy today who had one of freedoms modules installed and he said that his reads 18 kph from a dead stop until he reaches that speed, then reads properly. Just wondering if yours does this or if he's got a glitch. Mine reads like normal.
Thanks
Steve
