Tether kill switch instalation problem!
Old Apr 12, 2003 | 12:16 AM
love250x's Avatar
Default Tether kill switch instalation problem!
I bought a tether kill switch and the directions were no help at all! I attached the short wire to the frame and the long wire spliced to the black wire with a yellow stripe. Now my 400ex wont start. The fuse is good. whered i go wrong? thanks
Old Apr 12, 2003 | 03:11 PM
RacinJason's Avatar
When you cut the striped wire you left one end disconected when it should have been spliced into the connection, or you have the wires crossed
does the bike fire with the switch out?
Old Apr 26, 2003 | 09:50 PM
cluby's Avatar
well I don't know what kind of theather kit you bought but I don't remeber any yellow with i black strip cutting the ingtion on the 400ex I would go to your dealer and begg to look at the wiring diagram for your ATV.\
Old Apr 27, 2003 | 09:21 PM
love250x's Avatar
You mean that wire i cut was supposed to be connected ? I just cut it and spliced one end to the new wire. If it was supposed to be a 3-way deal, that would explain everything.
Old Apr 28, 2003 | 09:24 PM
RacinJason's Avatar
a 3way deal
Old Apr 28, 2004 | 01:27 AM
03400exrider's Avatar
ya its a 3 way deal. what i did was cut the black wire with the yellow stripe and striped both ends and then striped the long wire then conceted all of them using 3 circle wire conecters then conected the ground.
simple mistake
Old Apr 28, 2004 | 02:20 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
dont even need to cut it,,,,just expose the wire and connect to it (same as 3way deal),,,,,,just to ground it out
Bigredjeep
Apr 10, 2020 02:55 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
vipers
1) Engine problems..
May 31, 2015 09:12 AM
hotfmfblaster
Aug 14, 2000 02:49 PM
theowl
Dec 10, 1999 12:58 AM
