400ex clutch and kill switch
Old Dec 7, 1999 | 07:04 PM
theowl's Avatar
What is the hot set up to remove the behemoth of a clutch perch / emergency brake perch on a 400ex? How do you wire the safety switch? I need a tethered kill switch for mx. What is the best model and how do you wire it on a 400ex with key and slide switch?
Old Dec 8, 1999 | 01:54 PM
BenBoal's Avatar
The MSR Raptor clutch lever is better than the PEP, as I learned in this forum earlier this year (after I got the PEP on my 250R). The MSR won't eat your cable like the PEP will.
Old Dec 8, 1999 | 02:28 PM
kevhog's Avatar
Go buy a clutch lever/perch assembly, The PEP one's are really nice, and remove the old lever, and e-brake cable. You'll have to buy a block off plate for your caliper, but they're cheap, and you can get one anywhere. I think there is only one kill-switch manufacturer, Pro-design, and it's real easy to hook up. It simply grounds out your coil, so it would'nt matter if the key was on or not. Save all the old stuff, so when you sell it, you can put it all back to stock.
Old Dec 8, 1999 | 10:00 PM
tony's Avatar
yea the tethered kill switch just splices in on the wires goin to the slide switch. i just took mine off. wasnt usin it anymore.
tony
'97 banshee
Old Dec 10, 1999 | 12:58 AM
Team400EX's Avatar
I believe that the wire that you wire the kill switch to is dark blue with a yellow stripe through it. It should be coming out of a box between your gas tank and fender on the left side as your sitting on it. Then i grounded it to one of my fender bolts using a loop connector. It works awesome, Pro Design is the best, and durable. Hope this helps.
~~Mike
'99 400EX, FMF Power Core IV, Works Triple Rate Shocks, AC Nerfs, K&N Power kit, Renthal Bars, etc...
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Ripinandtearin
Dec 11, 2017 08:06 PM
Ripinandtearin
Jul 19, 2015 08:38 PM
sublime250
Jul 11, 2015 11:52 AM
