What to include in off road tool kit? - No jokes please!
Old Apr 13, 2003 | 01:50 PM
Lukester's Avatar
Default What to include in off road tool kit? - No jokes please!
I'm packing too many tools on my quad on trips into the woods. I put 120 miles on my 03 Trail Boss this weekend and the Boy Scout in me says bring it all. The tool box is ~25 Lb.'s with no single heavy item. What do I really need for tools? Thank you for the suggestions.
Lukester
Old Apr 13, 2003 | 01:54 PM
modquad's Avatar
One of those Co2 tire inflators, a Leatherman like multi-tool, smaller Cresent wrench. Small Mag-lite.
Old Apr 13, 2003 | 10:33 PM
tblazerdad's Avatar
A tire repair kit with plugs and Co2 inflator is a must.
Old Apr 13, 2003 | 10:36 PM
BigBadScrambler's Avatar
I carry slime, chain lube, a small socket set , channel locks, srew drivers, and a cresent wrench
Old Apr 13, 2003 | 11:00 PM
MichaelAZ's Avatar
dont forget new spark plug, matches,TP
Old Apr 13, 2003 | 11:22 PM
Farmr123's Avatar
Spare spark plug & appropriate wrench (more needed on 2 cycles than 4)
Leatherman type tool
Tire plugs & inflator (while Slime is great stuff, it should already be in the tires if you want it, the trailside is not the place to be adding it).
Medium sized vise-grips, preferrably with wire cutters (to cut the wire you get wrapped around the axle)
Folding saw (I once got a branch wedged through the front A-arm, with the end poking against the radiator. Couldn't go forward, and if I backed up it would have pierced the radiator. Sawing the branch was the only option)
Medium sized crescen wrench, or the new-style 'bolt head grabber' style Channel-locks
Old Apr 13, 2003 | 11:26 PM
kblazk's Avatar
how does co2 tire inflator work?
Old Apr 14, 2003 | 01:32 AM
Maddog419's Avatar
I would think it depends on the mach you ride, and how long the trips are. Or if you are spending the night with your mach and what you have carried in. I carry in about 100 lbs. worth of gear on KLF 400 yr 95, but I ride it if I'm doing a all day or night ride. Sometimes I'll start my ride at night, and be back at camp in the morning. You see a whole new world that way. But for tools I will carry new plugs, fix-aflat, manual air pump,plugs to fix a flat,tape,wire, alot of spare fuses,rope,tow strap,water drinking or just in case it over heats, small tool bag that came with the mach. And use it to do your maintence, that way you know if you have the tools you need. And on the other side of things to take to live on. The list will only get bigger, and yes I carry it all. 1st aid kit,cell phone,snake bite kit,maps,ect ect ect ect. Remember what you carry in can save a life, and when you put 120 miles in a weekend that's a hell of a lot of time things can go wrong.
Hope this helps.
Old Apr 14, 2003 | 01:36 AM
modquad's Avatar
The CO2 inflators just rely on the same cartridges you use for BB and paintball guns. The newer styles let you regulate the pressure a little more easily.
Old Apr 14, 2003 | 12:07 PM
pudljumpr's Avatar
All of the above and a buddy with a rope, cause on a looooong trip, you never know!
