Sport on diet!
Old Apr 15, 2003 | 11:13 PM
Martianman's Avatar
Default Sport on diet!
What are some of the different ways some of you guys trimmed weight off of your Polaris Sports?I just did clutch work,FTZ portwork,installed a 38 carb.I figured first off different tires and rims,any recommendations?I also blocked off oil injection,using Benol.Thanks for any help,Marvin
Old Apr 15, 2003 | 11:45 PM
talonhawk's Avatar
Try the ultra-light battery from HPD. It will save you about 10-15 lbs.
Old Apr 15, 2003 | 11:53 PM
ScRaMbLeRiZeD's Avatar
If your bumper and floorboards are steel than that is another place you can drop weight. You can pick up an alum. bumper and remove the floorboards. Just leave the rear bar to mount a footpeg to.
Old Apr 15, 2003 | 11:55 PM
GregV's Avatar
You can shave a huge amount by changing your swingarm to ONE OF THESE..
Also, if you can get away with it, lose your stock airbox set up and go with ONE OF THESE.
I have had these two items replaced and you wouldn't belive how much they weigh!!
Old Apr 16, 2003 | 12:39 AM
modquad's Avatar
Along with those other ideas, you can also get a front bumper from a 4x4 unit, the later ones were aluminum and inexpensive. You can also ixnay that 11 lbs up front (oil injection tank) and get a pump block-off plate. Removing the starter and having your flywheel shaved helps the revs. I have an opened up, aluminum snorkled airbox w/ K&N and outerwear to sell. Pre-mix at 40:1. Try HPD-inc.com for engine mods, and Hotseatperformance.com for suspension mods. Lot of great people here to learn from. Have fun!
Old Apr 16, 2003 | 12:57 AM
STecate925's Avatar
GregV, just curious, how much did the stock swingarm and airbox weigh?
Old Apr 16, 2003 | 03:15 AM
modquad's Avatar
Also, if you go with the thin film battery, make sure to add a bit of foam around the unit to help dampen vibrations/impacts. Helps the life.
Old Apr 16, 2003 | 09:59 AM
Bubba297's Avatar
Another thing, if you can five finger discount some titanium and have a buddy machine it for you like Ken does, you can really lighten it up.[img]i/expressions/face-icon-small-happy.gif[/img] Just kidding,Ken.
Old Apr 16, 2003 | 10:05 AM
scramblered's Avatar
swingarm and battery will save a lot on the rear,remove electric starter
save some pounds too along the oil-injection block off kit is a must on modded 400.
Old Apr 16, 2003 | 11:47 AM
modquad's Avatar
Bubba, [img]i/expressions/face-icon-small-happy.gif[/img] my account with Mettec and other sources runs long, and that's with receipts to prove that. Keep watching the ATV Sport pages, you'll see all the sources. Especially after the laptop/radar detector walking away, theft is a bad deal. E-bay even has Titanium surplus aviation gear.
