Split-fire Plug...does it help???
I need to change my spark plug and wanted to know which plug works the best or if anyone even notices a difference in different types of plugs?? TIA....[img]i/expressions/face-icon-small-cool.gif[/img]
the # of electrodes has no impact on performance. You cant have 2 sparks at once, they have to alternate. The only thing that a spark plug can do is be a little bigger and stick into the combustion chamber, thereby increasing your compression, if only a small amount. Just make sure you use a quality plug and check it regularly.
Don't waste money on the Sh!tfire plugs, they don't do anything for your performance. The stock NGK is hard to beat, but you can go to the platinum or gold pallidium plugs NGK makes. The ones with the VX suffix are the platinum ones, not sure about the pallidium ones.
I have a tesla coil and its spark will take more than one path at once (could be flashing back and forth to fast for my eyes to tell I guess). But anywho, it dont imagine it woult help unless you had a really hot coil, then it would help a touch but mostly make your plugs last longer.
BTW, automotive hot rodders add hotter coils.
Don't waste your $$ on the Split Fire - they are just a bunch of hype... Stick with the NGK or go to an Autolite.. I have had good luck with those for a lot less $$..
Hey...thanx for all the responses everyone. NGK sounds like the way to go. I'll pick some up tomorrow after work. Thanx again!!![img]i/expressions/face-icon-small-cool.gif[/img]
Cant remember the name of it, but the auto place up the street from my house carries ATV plugs, they even have a catalog to tell you what plug ur atv takes. They know me by name though because the RD eats NGKs like an Iraqi loots. Its the one that used to be named Auto Shack.
Most big time auto parts stores have that cross reference book that you are talking about on the plugs.... I have bought plugs from AutoZone, Advance Auto Parts, and Napa so if you go to one of those places they should be able to help you.....
