alltoys, you got them pistons in yet?
Prairiewrench,
Yes the new pistons are in I tested it last weekend. Before with stock pistons it had way to much out of the hole power, hard to keep the wheels from spinning. Also it over fueled at 3/4 to full throttle causing low detonation.
Now with the new pistons the power with the 1 3/4 screw is now at 74hp instead of 84 this is with the new cams plus I can use all the throttle without detonation. I ran up to 12 psi before it started to get hot with water injection I will be able to boost to 18psi. The horse power is down somewhat but the trade off is a more useable powerband. Instead of having to hang onto something on take off I can actually control the power better. Mind you it is still a pretty hairy take off with a very strong pull right through to top end. I can reach full rpm in 4.3 seconds or 72mph in a space of 150 ft.this is also with 27inch Outlaws. If I get time this weekend I am going to install the 2inch screws maybe the 2 1/4 inch screws to see what difference there might be. If I am lucky the largest impeller will put me in the 90hp range. Oh yes the new pistons reduced the compression to 6.02 - 1 perfect for the Super Charger. I also picked up a water injection system from a souped up Neon that I will work on the adaptation tomorow if wifey lets me LOL.
exmotocrosser
Sep 13, 2019 06:12 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
