TM 45 jets
Old Apr 18, 2003 | 01:10 PM
Eaglecollector's Avatar
Default TM 45 jets
Is the main jet for the 45 a small round head or is it the large round? I was told that there are two kinds. Is that true?
Old Apr 18, 2003 | 03:23 PM
hinglbyds's Avatar
Default TM 45 jets
The larger round are for the 45. I think there are two different large round. One is Mikuni and one is dyno jet. I'm sure someone will jump in here to confirm.
Also there is a chart that shows the difference in the two. Search for "jets".
Old Apr 20, 2003 | 11:53 PM
Hightower's Avatar
Default TM 45 jets
tm45 comes with large round, stoack carb uses small round.
you can use the small round in place of large round - the hole size is the same if the jet # matches, and that's all the matters.
you cannot use large round on the stock carb, because they will not fit up into the sleeve that wraps the jet.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
